man some of you guys aren't as geeky as I thought you were
1: check to see that you have the lights on your DSL modem... usually 3... make sure they're all lit... if you have a 4'th activity light that may come into play later
2: the fact that IPCONFIG shows media disconnect is basically your issue... I'm suprised you can ping anything without an IP so either you do have an IP or you just don't see it
3: I agree with what some have said but this may shed more light on ipconfig
a: ipconfig /all will show all the ip info
b: ipconfig /release use this prior to renew ... just do it
![Stick Out Tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
c: ipconfig /renew assuming you have a functioning dhcp server this will work
4: nothing will work if you don't have an IP so if ipconfig doesn't show you 192.168.xxx.xxx then somethings not right...
5: btw... does your ethernet card showing a green light??? is it blinking?? lol
so to sum things up ... check the lights.. make sure you're getting an IP... then in IPCONFIG if you've got an IP make sure the info is correct... the gateway is your router.... if you can get that far you're doing well... next thing to do is to look at your router config...
to look at your router you'll need to see the gateway number (shown in ipconfig) usually it's 192.168.0.1 or 192.168.1.1 or 192.168.1.254 ... somethin like that....
and as members have already told you... get firefox... that's great advice
and for everyone that said you can't troubleshoot without being there.... that's such a weenie excuse... I can come up with another 30 things to check before I weenie out like that
