todd hughes
Change oil on o4 srt 10 to day and thought i would check the bolt on the crankshaft and it was loose 15000 miles keep check on this very scary.
blue is for parts that you will take off and on, red is permanent unless heated before removelryan said:it says to use blue loctite but i used red!!!!!!!!
Troy's QC SRT said:why and how would you just check that during an iol change? Did you drop the oil pan?
Cruster said:The one on the front that holds the harmonic balancer on the front of the crank. Not inside. Dig?
