John Stuttle
These are the Doetsch Tech Nitro-Slammer shock part numbers for our trucks. I have personaaly used these shocks and feel they are the best ones next to the QA1 adjustables. Here is more info on them:
1-3/8" oversized piston bores, special progressive valving and 180 psi of nitro-pressurization. 180 psi nitro pressure prevents aeration and oil foaming common in non-gas shocks, preventing that "mushy" feel you get from a lesser shock after its hot.
Premium urethane bushings are used for the ultimate in long-term durability,preventing worn out bushings and loose shocks.
Teflon wiper seals are used to keep dust and road-debris from following the shaft back into the internals of the shock body.
Twin-tube shock design prevents accidental denting of the outer tube from damaging the piston and the inner cylinder of the shock.
Massive 9/16" thick chrome shaft gives you the strength and durability you should expect from a premium quality shock.
A high gloss black enamel finish with red bushings give these shocks a classy look with a clean, high performance touch.
A "lifetime guarantee" from Doetsch Tech If your shock ever leaks, breaks or just plain wears out.
The part numbers are 4093G and 4163G They are generally avaiable for about $40 each.
Happy Motoring - john
