Dyno'd JMB Midpipes W/H Flow Cats
NVR2OLD
VTCoA Senior Member
Rapid City, South Dakota
Last year I put my truck on the Dyno Jet with Andy from Dyno Tunes after I installed a BBK from JTS and CAI from JMB and Magna Flow with stock cats plus 170 t-stat. Elevation here is 3300 ft.-air temp 80-26.78 in-Hg and Humidity 19.
1st run: 434.41 rwhp/ 474.54 torq.
2nd run: 446.00 rwhp/ 485.46 torq.
This year I added JMB midpipes with high flow cats and put the truck back on the Dyno Jet with Andy from Dyno Tunes. Air temp 79-26.93 in-Hg and Humidity 31.
1st run: 447.13 rwhp/ 485.89
2nd run: 454.95 rwhp/ 492.19
Andy from Dyno Tunes said its still a little rich in the midrange and good for 10-15 more hp. I'm happy with the JMB midpipes and the way the truck sounds.
Thats badass man I think I might have to hop on the dyno out at sturgis to see how much i can put down with my rear cats removed.
soyou removed all 4 cats? or did you alredy have two of them out.
just goes to show how much hp cats rob from you
what is a bbk from jts? and do you have an exhaust clip?
NVR2OLD said:
BBK is a 67mm throttle body and is good for 10-15 hp and Tonys ported throttle body also works really good. I'll have to see if I can get a friend to do a sound clip on the exhaust for me.
I had Tony port my BBK
