Seeing that one has used a 12rib befor or those fans no one can really answer that question. You need to find out how it mounts and the thickness of it.
Just giving my personal experience with flex a lite fans has not been good. My brother and I along with some friends have had several of them burn up multiple times. Didn't last long at all. Just my 2 cents but I will never use one of there products on a project of mine
Our stock system works great! Electric is good but as said you have the current draw. Of course ours runs off power steering and in turn slows engine down a tad. Kind of a no win situation really. Either work well and serve their purpose. :rock:
The nice part I like about electric fans is they can be wired in to turn on with the truck off and or with a swith or dial,if you were to have an electric water pump(I'm working on that right now) then you could cool down the truck at the track with the truck shut off!
I tried the flex light setup and all it would do is smoke out the relays all the time after about two months .and I was using 50 amp relays .
With the fan I have now it is still on the 40 amp one I first installed on it .It did help when I put the roe radiator on it and it looks pretty like me :evil:
