ENGINE MOUNTS???
SNAKEGUTS
There are two big bolts that hold the engine mount to the engine mount bracket that is bolted to the engine.
What is the tourque lbs for these bolts?
I got the specs for the 3 bracket bolts...30lbs
And, I got the main mounting bolts/nuts...75lbs
Anybody?????:dontknow:
Thanks!:rock:
Thanks!:rock:
Also 75 ft. lbs. if you are talking about the engine mount-to-the-frame bracket...
Thanks, but I think you are talking about the bolt and nut that hold the mount to the frame of the truck.
I am talking about the bolts between the engine mount and the bracket bolted to the engine.
Anyone?:dontknow: :D
I have searched and searched, and coulndt find anything:dontknow:
but I would think it would be in the 75 lb range on those, they are def large enough for em:D
if it was me I would go about 75lbs
Oh...those...
I couldn't find those in the manual either, so I make them "snug" :)
Thanks guys!
I also searched and searched. I figure if the main bolts take 75 these sould
be about the same. 75 each or combined we will have to see.
I think I will have to just use my logical judgement on how much to give um.
I will monitor the tourque once they start to snug.
Also the factory one had a lockin adgent so they will get locktite.:marchmellow:
