71dusterjon said:is running 11.5 a/f ratio bad at the higher rpms with this engine?
71dusterjon said:gave up my tacoma to get srt10. met guy in yuma to pick up the truck that was coming from san diego.
previous owner went to dc performance to do the following:
paxton supercharger
170 tstat
ecu reprogrammed
centerforce clutch
tilton flywheel
clutch slave
X-metal shifter
fuel system upgrade
belanger headers
high flow cats
magna flow exhaust
lowering kit
Prof said:That is an ideal tune...tunes with that profile indicate someone who knows what they are doing. I run 11.5 a/f with a forged engine...but I wanted long life not max performance.
mauiSRT/10 said:Wizzy.........I think Patricks truck was wrecked a while back.
71dusterjon said:ok well i just put the truck on the dyno again because i have been having some problems around 4500. below are the hp/boost graph and the torque/hp graph. I forgot to get one with the a/f ratio but when the guy was on it stayed around 10 and then at 5 started to climb close to 12. I have called Dan at DC performance since they did all the work and will be sending him the graphs to see what he thinks.
Also what's the best programmer out there for this truck since when i asked dan if he could send the tune file and have a dyno shop tune my engine he asked if i had a programmer, which i obviously dont.
