earl lee
On the stock flywheel are they noisy in general? Im just curious if its time to change mine out. Thanks
Can you describe the noise?
I'll make a video but it sounds like something rattling around.
My clutch is new well fairly new (put in last year) but the noise is the same even before it was replaced. Ive replaced everything except the flywheel. I also put in another OE clutch.
So assuming the flywheel has never been replaced it has 85k on it now. I dont have any driveablity issue, it is just noisey at idle.
Both my Trucks did/do the same thing. When in neutral, after driving for awhile, I can hear something around the clutch area "knocking" Push in the Clutch and it goes away.
This is what I'm referring to as well. It also does it from a cold start while on idle.
All the parts that were put in to my truck were used so they should be reasonably worn in. I'm wondering if these trucks are just like that.
Thats the sound and same situation. Sounds like it is normal then since your trucks have lower miles im in the 85k range with mind. Its not a big issue it just makes the truck sound raggedly at the light with the windows down. Its like oh gawd that sound is horrible.
When I hear irritating noises in my truck, I just floor the loud pedal. No more nagging wife, complaining neighbours or pesky sirens!
It's gear rattle and completely normal. Clutch disengaged, whether in neutral or not, the input shaft is spinning and causing the gears in the transmission to "rattle". I believe this sound to be the reason Chrysler recommended gear oil in the T56 as opposed to ATF.
Wait... So we aren't supposed to use ATF+4???
