FOR SALE
doneo
NJ
MOPAR / Borla Cat back Exhaust....was installed for three weeks
X-Metal Accu Sump oiling system....brand new in box
PM me with an offer
More to come just can't remember anything else at the moment
What is the XMetal accusump oiling system ???/Have any pics ??
Yes, pics doneo!
Here you go Don... and those interested in the X-Metal Accusump....
:D
nice help with the pics NBT Thank You
Anything for you Don.... can't wait till the Nat's:rock:
How much are they new?
Interested in the Accusump!
Also would like to know how much they cost new.
If I recall it was $445.00 new.... would have to dig up the slip... but that's pretty close.
Do you have it installed in your truck. Any comments on it?
Nope... never got to the install...and off it went to another member who WILL use it, and WILL need it from the sounds of the build
Ahhhh..... Ill think about it Doneo Ill PM you if I make a decision.
Thanks NBT.
Dominick572 said:
Thanks NBT.
Yep... If you want more specifics you can call Boomer, or...
On initial start-up when the valve on the oil side is opened the pressurized oil is released into the engine and therefore pre-lubricating the engine prior to start-up.
The Accusump holds whatever oil pressure the engine has at the time that it is shut off.
After the engine is started and the oil pump has taken over, oil is pumped back into the Accusump.
This moves the piston back and pressurizes the Accusump until it equalizes with engine's oil pressure.
While driving, if the engine's oil pressure is interrupted for any reason, the Accusump releases its oil reserve again, keeping the engine lubricated until the engine's oil pressure comes back to normal.
This release of oil could last from 15 to 60 seconds, depending on the size and speed of the engine.
In racing or hard driving conditions, the Accusump will automatically fill and discharge when needed as you corner, accelerate and brake.
It's great protection for sure...and if I had half a brain I would put it on....more now so, since I put the SC on it.
I just got way too much other shit going on right now.
Received it today Doneo! Thanks.
Anyone have the directions electronically?
