Here is the write-up from Pro-Touring (dot) COM....
Hi Pro-Touring Members,
At the 2009 Performance Race Industry (PRI) show this month, we debuted a new motorsports transmission product... Introducing the
KEISLER ROAD & TRACK 6 SPEED
RATIOS: 2.44 1st, 1.61 2nd, 1.23 3rd, 1.0 4th, 0.88 5th, 0.77 6th
* This is a closer ratio gear set than the production 6-speed found in Corvette, Viper, Camaro, Mustang, Challenger. This means your engine rpm will stay in the power band between shifts.
CLUTCHLESS UP & DOWN SHIFTS:
* Once you launch your vehicle as normal with the clutch, all UP and DOWN shifting can be done without the use of the clutch pedal.
* Shifts are RAPID - as fast as you can move your hand, you are in gear during upshifting. A slight lift of the throttle or momentary retarding of timing allows the clutch teeth to disengage. Shift effort is EASY and SMOOTH. Downshifting is easily accomplished by lifting throttle, pull handle out of gear, quickly tap the gas to raise the rpms (about 500rpm), then push the handle into gear. Again, very easy effort.
* If you want to use the clutch - that is OK. There is no demerit to using the clutch, and you can feather the clutch on as normal.
* Street driving FRIENDLY - once you learn how to rev match the downshifts (couple hours at most), you will find the transmission to be well mannered around town and on the highway.
* Competitive ADVANTAGE - The ROAD & TRACK 6 SPEED, with its motorsports derived clutch gear system, provides you the capability of extremely high RPM shifts (>8500RPM), with repeatibility and reliability, that are not achievable with factory sychromesh transmissions (even triple cone). Sychromesh transmissions such as the T-56 (which use friction cones to aid in meshing the clutch gear teeth internally) are not designed to shift reliably past 6500 RPM, and will cause delayed and mis-shifts, or worse yet, failures during high rpm (>6500RPM) shifts.
The KEISLER ROAD & TRACK 6 SPEED will allow you to take your driving skills and car's potential to the next level, at a price approximately 1/3 to 1/2 that of "entry level" motorsports transmissions. And the beauty is that with Keisler's expertise in complete drivetrain systems, we can integrate the ROAD & TRACK 6 SPEED into most any muscle car, race car, or late model Corvette, Mustang, Camaro, Challenger or sport truck.
Check out this video that shows the product in action. Please note that I did not use the preferred downshifting method due to my mistake. BUT you can see how easy it is to downshift ... and upshifts are very fast.
<VIDEO>
PRODUCT INCLUDES:
1. COMPLETELY ASSEMBLED AND PAINTED ROAD & TRACK 6-SPEED *REQUIRES T56 CORE*
2. EN 36 / SAE 9310 CHROME-NICKEL-MOLY EXTREME DUTY STEEL GEARSET
3. CNC HELICAL CUT GEARS, FACE-ENGAGEMENT CLUTCH/SLIDER GEARS, 1-1/8INCH X 26 SPLINE INPUT, 1-PIECE CLUSTER GEAR SHAFT
4. COMPUTER CONTROLLED HEAT TREATMENT
5. CHEMICALLY TREATED, TUMBLED AND POLISHED
6. CNC MACHINED BILLET STEEL, HEAT TREATED AND FULLY POLISHED SHIFT FORKS, EXTREME DUTY
7. CNC MACHINED BILLET STEEL, HEAT TREATED AND FULLY POLISHED SHIFT LINKAGE, EXTREME DUTY
8. PROFESSIONAL GRADE SHIFTER W/STOP RING, PRE-INSTALLED, EXTREME DUTY (accepts standard 2-bolt style handles)
9. HIGH HEAT ARGENT SILVER, ELECTRIC BLUE PAINT, OR PAINT DELETE
OPTIONAL $60 LUBRICATION PACKAGE
10. MOBILE 1 FULL SYNTHETIC, 4 QUARTS
11. REV-X FRICTION REDUCTION ADDITIVE, 1 BOTTLE
ASSEMBLY INCLUDES:
1. RECEIVING & INSPECTION OF CORE
2. COMPLETE DISASSEMBLY OF CORE
3. HOT CLEANING & BLASTING OF HOUSING
4. CLEANING & INSPECTION OF ALL INTERNAL COMPONENTS
5. PAINT HOUSING
6. ASSEMBLY OF GEARSET, PRECISION SHIM & PRELOAD
7. ASSEMBLY OF SHIFT SYSTEM
8. ASSEMBLY OF EXTERNAL SHIFT MECHANISM
9. PRECISION ADJUSTMENT OF EXTERNAL SHIFTER STOPS
10. FILL TRANSMISSION WITH 4 QUARTS MOBILE 1 SYNTHETIC W/ REV-X ADDITIVE
11. TESTING & INSPECTION ON TRANSMISSION TEST STAND AT 4000 RPM
12. LEAK DECAY INSPECTION ON AUTOMATIC EQUIPMENT
13. BUILD DATA, INSPECTION REPORT STORED WITH SERIAL NUMBER
14. WRAPPING WITH PLASTIC WRAP, BANDING TO SPECIAL WOOD PALLET
15. PREPARATION OF ALL PAPERWORK FOR DOMESTIC OR INTERNATION SHIPMENT
__________________________________________________ ___
PRICING AND AVAILABILITY INFORMATION
6G (1st thru 6th gears upgraded; Reverse remains synchromesh)
PRICE: $6,495 + $995 ASSY
4G (1st-4th gears changed out; 5th/6th/Reverse remains remains original sychromesh)
PRICE: $5,695 + $995 ASSY
LEAD TIME:
4-6 weeks from receipt of order and YOUR T56 core. If you don't have a core, we can provide one.
For a very limited time, to help seed the market, I will extend you HUGE discount of OVER $1000 OFF
1. Assembly $995 - FREE
2. Extreme Duty Oil Package $60 - FREE
I believe you will find this to be an extremely attractive package for a very special, high grade niche street and racing transmission.
To inquire further and to purchase, either PM me or email me at
[email protected] Or you can call me direct at 865.566.0314 8am - 6:30pm eastern. I am personally handling all sales of this unique exciting product.
And as always, you are welcome to visit with me at our facility (10min from the Knoxville airport), and we'll go for a drive! Comments are welcome, and watch our website and videosite for more info.
Shafi Keisler, pres/ceo/founder
Keisler Engineering
