Found the culprit to no rear turn signal
4to10cyl
Cadillac, MI
Since I got the truck it hasn't had a right hand rear turn signal. I replaced the bulb with no avail. So tonight I started going through wiring and found that the spare tire was smacking into the wiring harness that is clipped to the driver's side frame and it was cutting wires in half. Rewired the two wires, tightened up the spare tire, and problem solved. Much easier than I expected. :rock:
this should be a sticky as a reminder for everybody to go and check thiers before its too late....good find. if its happening to yours, it more than likely to happen to everybodys...
