FS: OEM and Aftermarket Ram SRT-10 Parts
JMB Justin
Preferred Vendor
Hillsboro MO
JMB rear mount battery bracket with hardware, no cables $50
Roe water injection control box $10
Torque limiter setup, worked great even with huge power $75
Stock Timing set $20
OEM oil pickup tube $5
OEM Air bag module $5
OEM coil (4 cyl one) $5
Oil/Trans Cooler $50
Steel driveshaft for RC with turbo 400 $100
Front fender support frame section (everything from firewall forward but actual black frame rails) $200
Trans crossmember with driveshaft loop built in for turbo 400 $100
Have two front QA1 shocks in great shape, $320 new, $200 plus shipping
Also a set of v6 ram springs, these improve weight transfer a bunch and lower the front end as well. $80 plus shipping, also have another set for someone who wants a LOW front (over 2" drop), $50 for that set.
Justin
V6 ram springs, great weight transfer and lowers front $80
Modded V6 ram springs, great weight transfer and extra low front $50
Hood realese cable assembly $10
Oem oil pick up tube
Justin,
Me again, is this an internal motor part, or something outside ?
I have an issue during an 04 engine rebuild and looking for a
solution.
Maybe you can help.
Arne
How far do the V6 springs lower the front end? Also how far do the modded springs drop the front end in comparison to the stock springs?
justin can you give me length measurement on the driveshaft? I think i could use it for another project I have. Also, what size you joint for the rear? 1350?
I will take the V6 springs, just wanted to get an idea how far they lower the front end.
