FS: Polished 2.4L Roe Supercharger
apaden
- unit is powder coated black with polished supercharger, fuel rails and
throttle cable bracket.
- intake manifold has been fully ported by Greg Good
- comes with 6 1/2 and 8lbs pulley
- Vec 2 that has been upgraded to Vec 3
- 3 tune cards
- 53 lbs low impedance injectors
- Vec Driver Box
- Wiring harness
- Full instructions for Vec and Supercharger installation.
- It will come with a brand new set of bolts for the intake manifold.
- Blower support
- All other necessary hardware required for installation.
- Only thing you will need is your IAC valve which comes off your stock
manifold, new intake manifold gasket which can be purchased for around
$30.00, a Roe Cranshaft Pin kit which are available from Roeracing. There
s only 690 miles on this supercharger.
- everything will come clean and will be carefully package.
- I have never had an issue with this supercharger, nor with the vec, it has
worked great for me. I used methanol injection and have not had an
issue with the heat soak either.
- Asking $4700 Shipped .
Contact me via PM or text (860) 337-4230
Thanks
This is for a truck or car?
Sent from my LG-H918 using Tapatalk
this is for a car, I will also list the supercharger for my truck in a minute, since is also for sale.
Thanks
You're on the wrong site to sell a Viper (not truck) blower. At that price it would sell within a few hrs. How is it the blower only has 690 miles? If you were closer and I could pick it up I would grab it.
