Streetgliderx
- Joined
- Oct 8, 2008
- Messages
- 520
- Reaction score
- 1
OK lets start from the beginning, my truck has torrie tune, runs 14.8-15.0 AFR cruising and 12.9 at WOT. Now after a TB change I still get cruising AFR but at WOT now best I have seen is 13.8-14.6
Now I just bolted on a JTSV throttle body. At same time I noticed there was no small line from the side of the manifold to the breather hose so I added one there. little short 3/4" 45* hose. I had made some changes to the catch can lines but I have returned them to the way it was before so that shouldn't be a cause here.
Now only real issue I had with swapping TBs was there is one bolt broken in my manifold. but since it didn't affect the stock TB I would think its not the issue here.
last thing I have done was swap out to my manual pedal basket but I don't see that changing anything, my scan tool shows throttle position at 18.2 idle then 90.3 WOT and the pedal gives me full open on the TB.
what would have caused this change in WOT AFRs? I have even swapped my tunes among my three and no change.
I'm almost wondering if my autometer wideband sensor is reading wrong?
