Jul 5, 2013 #1 SinorSwim Full Access Member Joined Oct 5, 2006 Messages 94 Reaction score 0 Location TORONTO I noticed driving to work that my oil pressure gauge is reading max (100 PSI)...what is the problem? 2005 RC 80K. Checked oil level and it is ok or a bit low. TIA
Jul 5, 2013 #2 mopar-or-no-car Full Access Member Joined Sep 18, 2012 Messages 3,086 Reaction score 0 Location North West Ohio If it was mine I would first verify the reading by testing the pressure from the block....could just be the gauge or sender...
Jul 5, 2013 #3 ZCx Active Member Supporting Member Joined Sep 13, 2007 Messages 9,803 Reaction score 19 Location Big D sounds like its pegged/grounded out. sensor is the most common. possibile wirin prob. does it go to zero with key off??? does it go to 100 with just turnin the key on???
Jul 5, 2013 #4 SinorSwim Full Access Member Joined Oct 5, 2006 Messages 94 Reaction score 0 Location TORONTO just checked... when the key is turned to the on position (engine not running) the gauge reads 48 PSI. the gauge goes to zero when in off position. Thanks...
Jul 5, 2013 #5 ZCx Active Member Supporting Member Joined Sep 13, 2007 Messages 9,803 Reaction score 19 Location Big D i'm bettin sensor. a few have had gauge probs also. can ya unplug at the sensor & see how the gauge does then???? Attachments 100_0262.jpg 752.5 KB · Views: 808
Jul 5, 2013 #6 VENOMOUS1 RACING Has Left the Room - Banned from VTCOA! Joined May 15, 2009 Messages 12,751 Reaction score 2 Location Wacko Waco,TX Yup likely the oil pressure sender. Do like ZCX said and unplug it then see reading.
