How to tell??
05ce80
Iowa
Is there a way to tell if a truck has a tune in it? I bought mine used without any history. Thanks
Did you talk wit Jeff from viper truck registry . Maybe he got some info , and you should send a pics of a door sticker and your VIN to Jeff so he can add you truck to registry .
And other thing is , maybe you cab go at your lockal dodge dealer . They can run your VIN. And tell you everything on a truck . Including when she was serviced .
If you DON"T have Any Warranty on it, the Dodge Dealer can hook up the StarScan tool and tell you if it is a Factory Tune or not...
However, IF you DO have Any Warranty on it and the Dealer finds Anything other than a Stock Factory Tune they will Void the Warranty...
The Only Exception to this would be if the previous owner purchased the Mopar Performance PCM. The Dealer can check that as well....
Hope this helps :)
I have no additional info on the truck if its 80 of 200 CE
