I noticed that my truck is idling lower than usual and when im coming to a stop and i take it out of gear and just brake to stop it bogs down like its gonna die out.. Any ideas what it could be ?
You can remove the hardware then the selonoid. Clean out any carbon build up with carb or throttle body cleaner. Also clean the throttle body & blades. You should have a small air gap around the two blades when they are closed
