Installed Bosch iridium plugs one went bad want to pick other plug brand Which one no
GrayghostSRT-10
Installed Bosch iridium plugs and one went bad and coded bad injector p0209 found plug wet which means bad plug
Change out the one plug with an old champion I had and now ok
Well I no longer trust these plugs after reading that they are junk
What I have read is that NGk iridiums are good also v-type NGk is also good
What does everybody recomend?
Some say iridium ngk one heat range colder
I have mopar long tube and open exhaust no cats and cold air intake
Advice!!!!!:
I was gonna say ngk but most have covered that, tr6's are a real good plug and very cheap
Thanks for the tips. I am going with NGK Iridium and one range colder than stock recomendation.
Honestly I wouldn't even do the iridium, just the reg copper, they are a great plug zero issues with 16psi boost
I prefer Champions also
Bosch junk is out
Iridiums are out and champions are back in.
BIG mistake will never use bosch again and only stick with champions
Truck runs perfect again
Moral of the story ONLY use Champions
As others have said don't waste the coin on iridiums, I'm a fan of NGK over Champions and always have been. I run NGK TR6's in my 600 RWHP Cobra without issues. Champions will be fine though.
