Tonkasmith
Been googling heat exchangers online and trying to find one that's at least 36 inches wide by 8-16 tall and 2-3 1/2 thick. Any websites other then frozen boost that anyone knows about. Thanks
i got mine from cxracing.com
good luck
I also have two of the heat exchanges too that go above the exhaust manifold, a polished one and a yellow powder coated on.
A heat exchanger that goes above the exhaust manifold? Is that right? Trying to wrap my had around that one. That just doesn't sound right.
I went with the 26x7x3.5 type 101 from frozen boost and the I ordered an upgraded intercooler From them as well it's a 12x12.5x4.5 little bit different inlet/outlet setup for the water coming from heat exchanger and going to pump, but it's minimal total setup makes intercooler maybe 30% larger give or take but the heat exchanger must be 3x's as big as the factory one. Also the intercooler fits on factory bracket so that will save time not trying to reinvent the wheel. All inlet/outlets for charger are exact same size as well the lines between intercooler and heat exchanger all match up so nothing to hard there. Right now I am putting on paper which connectors i need and am going to swap everything to stainless lines with blue/black connectors. Santeen would it be worth custom fabbing a pipe down to front center of bumper and then putting on the k&n 2 filter setup on the end of it. Thought it would look trick and help clean up the upper engine bay. I already put an adaptor on the SC intake and put a full size cone filter on it and put it directly over the hole on the passenger side front valance used zip ties to hold it in place and no problems with it at all. Thought this idea would be good and I could put heat shields around intake pipe then. Lol now I am trying to reinvent the wheel.
Can u post the links from the frozen boost site, for those two parts? If it's the water/air intercooler that I think it is, it has nowhere to mount the BOV. Remember, Paxton's water/air intercooler has the BOV mounted to it.
At frozenboost.com go to water/air intercoolers it's the second option on left then click then once it loads scroll down to fifth intercooler on right and its the fifth one down type 103 for 149.99. I thought it looked like it had the hole for a blow off valve bit maybe I am confused by it's shape
No, if u look at the diagram, those are mounting holes on the side. As for the heat exchanger, i looked at that one originally, but I thought I would have to cut the bumper for it to fit.
Also do you know where or who makes an upgraded intercooler I can't find one but a few guys on here have pics but no one is responding to my pm's
I already cut the front bumper and my old man runs a water jet machine at work so he is making brackets for me that will bolt right into the front of the frame (I cut out the middle section/bottom) And planned to bolt directly in front of the vents on the bottom of the front bumper. So do I have to have a bov I assume yes but thought I would ask and are you running the stock intercooler.
That triangle piece is the intercooler. I think these guys are just relocating the BOV.
