Interesting combination/ twin turbo with supercahrger
sparticus
this is something that i had thought about because with the dsm's that i have built we have used compund turbos to get lots of power out of a small displacment (2.0) i have thought about it on my 05 qc in passing since im doing a paxton install and if i do and engine build i would not be able to see max power with just that. Well today i came across this article look like it works. Maybe run dual comp oiless turbos in the rear and dual in single out air to air which goes into supercharger??
id like to see what you guys think?
here is the link ....
Adding Twin Turbo Power to a Supercharged Shelby Cobra Mustang | Horsepower Monster
Doesn't work well with centrifical blower. That kinda set up is mainly for screw type blowers that are limited to power because of size and heat they create. Your Paxton would hold the turbos back. Alsoight want to do some research and reading before you ho mounting turnos in rear of truck for some odd reason that no one can really explain they make our motors go boom even built ones. Good luck
