jtsvp 2/4 lowering kit
You'll have to slot the control arm openings for camber adjustment, caster is non adjustable.
I got an alignment today and the shop couldn't get within the parameters. I ran out of thread on the tie rods for the toe adjustment. The camber or castor was also out of room for adjustment. Here's a pic of the print out. Will an alignment adjustment kit fix this?
Welcome to the reality of lowering. If you want the low look this is the trade off. Good luck, this usually opens the door to more problems such as bump steer and driveshaft vibration.
Pretty much every thread regarding lowering is followed up with more threads about issues encountered.
It does look good though.
I once tried to level out one of my tricks (ford) could never get it aligned properly. Ended up not doing it. Yet all my cars I've lowered no problems. Dang trucks.
