leaking water on raining days
marty pierce
on raining days both drivers and passenger sides leak water from the pull up handles i had my front windshield replace 6 months ago and i thought that was the problem 'till they said its coming from the sunroof draining tube. it is back up so its not draining down the tube. cleaning the tube from dirt suppose to fix the problem. i am wondering if anyone knows for sure is this the problem. and is there a fix for this leaking water problem.
yes you need to clean those drains...dirt and leaves get in the tubes.... keep them cleaned
It's one of three things:
1.) Tubes are clogged- I originally thought this way my problem cleaned, light rain no more leaks, thought it was fixed poured and started leaking again so I took it in... which leads to 2
2.) Sunroof is not sitting flush- See the thread I made a little while back(Above) and it'll fix all of your problems... DO NOT TAKE IT TO THE DEALER FOR THIS
3.) Seal is bad- Pretty self explanatory, test your seal after realigning your sunroof
