This is awesomly weird...glad I saw this thread, it might save me from shooting myself in the head someday when I'm replacing bulbs
SilvrSRT10 said:I'm just grasping at straws here but what happens if you turn the bulb around 180 degrees in the mount? One end should be +12v and the other Ground. If you have them in backwards that may be causing the odd behavior. I haven't tried messing with the LED bulbs so I don't know for sure but that might be something to try.:dontknow:
Well......it was worth a shot. It would seem to me in a DC system that they would have a positive and a negative pole on them. Like I said, haven't messed with LED's so I wasn't sure. Now I know with some tail lights they needed a resistor of some sort because the current draw was so low that it would give a "Bulb Out" indicator on the dash or the turn signal would act erratically. Very strange this electrical stuff.Carlwalski said:Yup, I concur, no change. The ends of the bulbs look identical so flipping them does nothing.
Thanks for the help all the same bud.SilvrSRT10 said:Well......it was worth a shot. It would seem to me in a DC system that they would have a positive and a negative pole on them. Like I said, haven't messed with LED's so I wasn't sure. Now I know with some tail lights they needed a resistor of some sort because the current draw was so low that it would give a "Bulb Out" indicator on the dash or the turn signal would act erratically. Very strange this electrical stuff.
I tried LED bulbs on my work truck. The Stop and Turn signals use the same bulb. When I would turn on the turn signal it would blink really fast. I think it could be fixed with an electronic blinker module but I didn't take that step. There wasn't enough resistance in the LED's to make the thermal blinker control to act right. The bulb out indicator wasn't a problem on our trucks that I know of. This was on a friends vehicle some years back. Good luck figuring it out.Carlwalski said:Thanks for the help all the same bud.
I have never heard of the bulb out indicator for the tail lights?
I know there are issues with some HID headlight kits, but not the tails?
LOLOL Carl is gonna kick your ars buddy LOLOOOL505'sFastestViper. said:led lights do not require higher wattage hell it would be a lot less would be my guess.....it seems like everything carl does kicks his ass hahaahha here is a joke i just thought of...how many new zealanders does it take to change a light bulb lol more then one thats for sure!!!!!!
Carl's problem is his LED overhead lights. I was having the problem with the LED tail lights on a different vehicle. I just need to get an electronic blinker for it when I get around to it.Vman455 said:If you swap to LED taillights and turns, you need load resistors wired inline. On older cars, you can switch the flasher in the fuse box to an electronic one, but these trucks have that damn TIPM or whatever--no separate flasher.
You are correct. LED's require very little current and they have very little resistance on the electrical system. On older vehicles with thermal blinker modules the LED's do provide enough resistance for it to act correctly. They end up flashing very quickly or erratically. They can also give a false bulb out indication.505'sFastestViper. said:led lights do not require higher wattage hell it would be a lot less would be my guess.....
about $10 fix buddySilvrSRT10 said:Carl's problem is his LED overhead lights. I was having the problem with the LED tail lights on a different vehicle. I just need to get an electronic blinker for it when I get around to it.
Carlwalski said:So what sought/style/part # are you guys with working aftermarket bulbs using?
SpudRacer said:Big Dave came over to "the other thread" to ask me to come over here to help you out.
My credentials?? I have replaced EVERY bulb on my SRT10 with either HID, or LED (including the dome lights). What you need to install bud, is a small resistor.
