Stinkers solid billet blocks are what I did. I used 2 inch blocks. 1 3/4 will level it out perfectly. 2 inch gives a slight rake. If I were to do it again I would use 1 3/4. He sells them as a kit with new U bolts. Great quality.:rock:
If you just want to level it use shackles. If you are going through the process anyway, I would lower the truck. I used Stinker's drop kit and love it. Not only does it make the truck look classy, but it also rides and handles very well. Check mine out....good luck man:rock:
