New To Me
Lost my hood scoop at 110mph today. I found it not a scratch on it. Next project make some new resin posts to screw that sucker back on.
I replaced mine last year. When I bought the truck, the scoop was cracked to hell and back. I bought a new one and the attach hardware from Th Viper Store, and had it match painted at a body shop. I added a strip of the 3M double sided tape on the fwd end of the scoop, to help make it stay on the hood better.
All fixed up now. Also fixed the hood insulation and the firewall fluff that didn't get blown off after I took the Volant dorky scoop out of the hood scoop, because the air doesn't go into the scoop...right? Sort of proves there was a shit load of air going in that NASA Duct style scoop and when the CAI was removed it destroyed the insulation. So the CAI dorky scoop thing is back on, even if it only stops the insulation getting tore up. I have a hunch it will do more than that at 130+mph. Next outing I shall plug the laptop in and watch the air intake temp. That is what that area between the seats is for, the laptop lol
20200530_154844 (1280x1280) (2).jpg 20200606_115819 (1280x1280).jpg 20200606_115712 (1280x1280).jpg 20200604_151005 (1280x1280).jpg20200606_114522 (1280x1280).jpg 20200606_115834 (1280x1280).jpg
Went out of town for a change. Our roads are shit compared to US but still managed good fuel driving at the speed limit. Trip was approx 300 miles/500km
More than happy with the outcome
20200701_133302 (1280x1280).jpgMPG US Or metric L/100km 20200701_133310 (1280x1280).jpg
I can't see me driving like that very often. Maybe only on long trip. If I ever get down the South Island the roads are straight and flat so it should do even better
That works out to 21 Imperial MPG, which is amazing.
I don't/can't use the Overhead Calculator myself as I've changed to a larger capacity fuel injector. Since doing so, the O/H claims I'm getting around 30 Imperial miles per gallon (not bloody likely).
On a road trip with plugs gapped at .040, I'm pretty consistent at 18 Imperial.
Rock On!!
Rock On!!
Yeah I am stoked my tune and coils are paying for themselves everyday I go out. Be even better with an undrive pulley
I wonder if the exhaust cut out should be open or closed. I figured closed as the lower flow at low revs would need a better chimney effect.
Wow 18 is great with the internal work you have had done and gizzillion hp
I always figured you are getting things right when they can return good mpg....can
Hell post a pic of 30mpg off your O/H you win hahaha
I was getting 20 mpg out of my 68 Riviera I thought that was good
I suppose you could always make a tube to fit the square hole and have that as your intake and cap the under hood contraption.
Maybe cut a bigger round hole to fit a standard sized pipe. Certainly be no drama about low pressure or hot air or having it block the hood scoop that let's the hot air out. To me it seems like an easy solution to the many posts on the issues of Volant CAI's
Kiwi, did you remove the hood scoop duct? And another question, does the box mate to the factory rectangle cutout that is common to the right hand fender well? Any info will be welcomed.
Yes I did remove the scoop duct. But after all the under hood insulation and firewall insulation was ripped off I put it back on. Also a place to store it on the trip down. Proved to me how much air was being pushed through there at 140mph. Yes the hole in the inner guard matches the box hole. Mine also has hole in behind grill
Went for a blast today just because I could. Thought this is a nice road so going back and planted foot and easily cracked 150mph with exhaust closed running on 95RON
Will be interesting with exhaust open and 100+ RON and the better tune....stay tuned....tuned hahaha get it!
What do you mean exhaust closed? You have electric cutouts?
