O2 fuse
wamb26
Jacksonville, FL
Can anyone point me to info on blowing o2 fuses. started throwing o2 related codes, and I think the trans is in safe mode. Had the transmission serviced and they said it has no problems. Truck will idle all day but can't drive it. I have replaced All 4 O2 sensors twice as a set and nothing changed
So what codes r you getting?? Sounds like a curcut problem.
P0031 2/1 o2 sensor heater circuit low
P0051. 1/1. o2 sensor heater circuit low
P0136. 1/2. o2 sensor heater circuit malfunction
P0152. 2/1. o2 sensor shorted to voltage
P0132. 1/1 o2 sensor shorted to voltage
No melted damaged corroded or pinched wiring or plugs found.
I currently have the fuse block out of the truck. All pins and plugs appear as new.
I would start at the o2 harness plug in and ohm out each pin from the pcm and hope it didn't short out the driver in the pcm.
Thanks for the info. Hopefully I will be able to put some hours in it this week, I'll let you know what I find
