OBD2 port not working
Mighty1
Miami, FL
Had the aeroforce gauge plugged into that port and was working fine then went off. I thought maybe something was wrong with the gauge so I plugged my SCT into that port and it won't come on either.
Any ideas what I should check for? I don't see a fuse for that port unless it is called something else.
Make sure all the pins in the OBD connector are still in. There was a member who I helped because his pins came out of the connector.
All of the pin receivers look like they are there although there is not a receiver for every slot. I just pulled every single fuse and all were good as well.
Well it started working again for some reason. Not sure what happened.
Thanks for the help!!:rock::rock:
Check all your fuses, especially the one for accessories.
Yea i think there may be a fuse for the OBD2 port if not like err76 said may be one of the accessory fueses but kinda odd that it started working again lol. fuses dont unpop lol
