Oil Leak
gwarwon2
Is this oil leak coming from the oil cooler lines? :dontknow:
yes.
time to replace/update
might want to check your p/s lines also
Yeah, definitely the oil lines
thx for the input. I just ordered a set of braided lines from JTS to replace them. Hopefully after this replacement I wont have to deal with them again.
Had my lines about 18 months & still working good. They were leaking so bad it looked like the right side of the rack blew out. Made the dealer replace them before I bought the truck.
Had my lines about 18 months & still working good. :rock::dito::rock:They were leaking so bad it looked like the right side of the rack blew out.:dito::rock::dito: Made the dealer replace them before I bought the truck.
had the same thought, lol
You won't be happier!
I hope you have smaller hands then I. I had an issue where the lines went to the block. I thought they were on good enough, turns out I was wrong, oh so wrong.
Was it anything like forgetting to remove the old oil filter gasket?
Seen that with a 5 quart system but 10 quarts, oh my!
Update: Replaced my lines with ones from JTS looks great and no more leaks. They were real easy to install also. Thanks
