howdy,
just an update on the oil filter "whine" thingie that i had been chasin for awhile.
got in touch with Kevin & he hooked me up with the fix for it. basicly a redesigned valve assembly.
have run it it different temps.,outside, & the same r.p.m.'s & engine temps. no prob.
thanks Kevin :rock: :rock: :rock:
the photos are of the old valve installed. have to take off fan belt & remove a/c comp. & swing out of the way
old valve removed
tried a shot down the by-pass bore
the last one is of the 3 styles that i know of.
top one is stock
middle one is what ya get when you order it from Dodge. looked way too short to me. Dodge updated the plunger & spring & not the cap.
bottom one is from Kevin. a bit different.
:rock: :rock: :rock: :burnout: :burnout: :rock: :rock:
old valve removed
top one is stock
