oil?
sublimeswinger
Santa Clara, CA
What type of oul do you guys suggest? Brand? And how much do these things take? Also, what oil temp should i be running? Thanks in advance.
Sorry. I meant 15-50. Ive never used anything but mobile one. And with k@n filters on both my srt's. Yea. Im in Dublin. If you ever need help with your truck let me know.
96,500 miles on 15-50 Mobile One. No rattle no problems and seems to run as strong as when I installed mods back at 20K. Uses a qt every 4K. Mopar filter 090 bought at Wal-Mart.
So the cap says 0-40. Is it needed? Also how is AMSoil? Or is mobilem1the best? Synthetic right?
0W40 Mobil 1 synthetic oil is more than plenty. Mopar 090 filter is also great.
Stock engine with basic bolt-on's will run cooler with better flow at all temperatures from start up to extreme Arizona heat with the 0W40. Still meets the 10 psi per 1000 rpm hot.
Cheers
Original owner. Mobil 1 0-40 with Viper oil filter. Changed every 3K miles....over 150K miles and still like new. Never gets that hot in Arizona...:D
