P/S 1' valve fitting removal.
VIPER-INJECTED
Woodlands,TX
Hey guys, I'm stuck out here in my storage unit trying to get the 1inch fitting off of the pump to install the JTS p/s lines. I already installed the line the fitting on the pump is the only one I need left. I there any special tool to get it off. I have a 1' six point deep socketdoesnt work. I can't get this fitting off. Thanks.
Trying to install the updated valve fitting.(BELOW)
I used a wrench but it sits at kind of a upward angle and the fitting was crazy tight
i used a deep socket, 1/2 extension & long breaker bar.
loaded it up till there was a good bow in the breaker bar & then popped it
anybody ever try an impact:dontknow::dontknow::dontknow:
Installed fitting.
Some of the tools I used will post more pics of other tools, just showing for ppl that don't know. If you have ?'s ask.
-used this electric impact its rated @ 60 ft lbs applied TQ, to pull underside splash guard. Prob best tool I use everyday.
Used this to pull 13/16 pressure line fitting nut off 1' fitting on p/s pump assembly.(used a longer extension *not pictured)
Here are some other tools. Finished up the truck tonight. I used some metric tools, I mainly work on Honda/Nissan vehicles.
DONE!!!!!!
