P0445 fixed, P0442 not, dropped the fuel tank and.....
Paul G
Been getting evap codes P0445 for large leak and P0442 for a small leak. Changed the fuel cap and the large leak code is gone. Just getting the small leak code. Went over all the vacuum and fuel lines, solenoid valve, all check good. Only place I could not check was on top of the tank. Feeling around on top of the tank one of the depressions with a device in it would be wet and smell of gas after a fill up. So I dropped the tank.
The device in the picture leaks when I presurize the fuel tank. What is this device? Can it be replaced or sealed?
Video of it leaking
I think that is for the evap. When you take the top off the tank can u see how it is attached on the other side?
It has to be attached from the inside. I can see no way to remove it from the outside. I Cant get the ring on the fuel pump to turn either. I called Auto Zone, they have a kit for removing the fuel pump, some kind of spanner wrench that will get the ring off the fuel pump. Maybe then I can feel around inside the tank for a lock ring under that device thats leaking.
That's your roll over valve. How much are you pressure are you using?
Using the discharge from a shop vac. Dont know how much PSI that might be. "roll over valve"? It has a large line going to it that could be some kind of fuel return line or maybe a tank vent line. The small line connected to it goes across the top of the tank to the rear, and conects to another device similar to this one just smaller. So it has to lift straight up since there is no lock ring I can see.
I'm curious because a small leak is not p0442. That is typically caused by a ldp pump which is pretty common. The evap system does not pressurize that much and depending how much pressure you put it may leak.
What is the ldp pump? I am going by this OBD II site. Looking for things on the list they show.
OBD-II Trouble Code: P0442 Evaporative Emission Control System Leak Detected (small leak)
Causes
A code P0442 most likely means one or more of the following has happened:
•A loose or improperly affixed gas cap
•A non-conforming gas cap (i.e. not factory/original brand)
•A small leak/hole in a fuel vapor hose/tube
•Other small leak in EVAP system
•Faulty vent o-ring seal
Possible Solutions
With a P0442, the most common repair is to:
•Remove and reinstall the gas cap, clear the codes, and drive for a day and see if the codes come back.
•Otherwise, replace the gas cap, or
•Inspect the EVAP system for cuts/holes in tubes/hoses
I have replaced the cap which cleared the P0445. No cracked hoses I can find. Only leak I can find is the one from the device in video.
I found what the ldp is. Leak detection pump. It presurizes the system and is extremely complicated. Found the service manual online. There is more to this evap system than an average wrench can handle. If sealing this leak dont fix it. It is going in to a repair shop. I think the device that is not sealing is the LDP filter, best I can tell from reading the manual.
This really sucks. The filter device, if that is what it is called, is not a removable item. No wonder it was leaking like a seive. The adhesive that seals it to the tank has let go. Napa, Oreilly, Rock Auto, Summit, no one lists a replacement fuel tank for the 10. Gotta check with the dealer tomarow. Or try to dig out the old adhesive and try to epoxy it back in. I hate to do BS repairs like that. Cant turn the ring that holds the fuel pump in either. Must need a special tool for that.
I bet you that gas tank shares a part number with another kind of ram. I would try the dealership to see what shares the same fuel tank
I tried to epoxy it back down. After I got my fingers un-stuck I went and bought the new tank with a new fuel pump o-ring. Ended up costing $525 with tax. They gave me a 10% discount for belonging to Mopars Unlimited of AZ. Put a half gallon of gas in and went and filled it up. Put 25.7 gallons in a 26 gallon tank. At least now I know where truely empty is on the gauge lol.
After all that work, did it get rid of the code?
I now have this same problem..... filled the tank as usual and it was pouring out fuel as I slowed down to enter the driveway!! Neighbor pointed to the splashing going on under the truck! That Vent valve arrangement should be a safety concern and a Recall. I am going to lift off the truck bed and see how I can re-seal that Vent...... wish me luck! going to superglue it down first , then epoxy it all the way around . I bet if I connect about 50 4" hose clamps together I could clamp it !...... :) this truck might need a match for a controlled burn rather than with ME in it! .... :(
P0445 fixed P0442 not dropped the fuel tank and
Great to hear. Crazy that its rusted like that. Was the car ever water damaged? Or gas previous fuel tank repairs.
After pulling the box off the frame I notice the fuel line came off the fuel pump. The rollover/vent valve was fine. :) The fuel line clip was broken and not sure if one side rolled or what..... I used a new clip and are cruising again! :)
Just an FYI, these adhesive seals on top of the fuel tanks deteriorate from OVERFILLING at the pump. The fuel will eventually eat away at the adhesive.
Just don't top off at the pump ;)
Cheers!
Cheers!
Ha! As we know its VERY hard to keep these trucks topped off. :D
Great info.. thanks!
