I am happy with the Paxton set I did, but now that I have gotten the exhaust to be quiet, the next annoying noise is the bypass valve.
The intake (from in the cab) is quieter on-boost than off-boost, because the valve is closed when on boost. When motor is on vacuum, the valve is held open. I am not sure if it is doing this to just let air in or if to let excess pressure out of the system to let the Paxton head unit "cruise". I am not sure is the bypass valve noise is just from the valve itself, or all that air trying to move through that little K7N filter.
I want to quiet it down. My first thought is to just put a hose on the valve and route the filter to be in fender area or in front of the radiator. Fender preferred, then it would muffel the sound from outside the truck too. I could also route it back into the intake system, prior to the Paxton, but why bother introducing heated air back in there.
Second thought. Change valve, would another model be quieter.
Anyone tried any of this before? Any other ideas (besides just keep it in boost) ??
