Pics for Justin
SNAKEGUTS
Allright sir, Here are the pics of the piece that needs welding.:rock:
No crazy angles just as the pic shows.:) Each pipe makes a 90 degree and just need to be straight with each other.
Im sure you can tell this will be the piece that brings the two 2.5" pipes together before the throttle body.
Also need the two meth bungs welded. These will be on the bottom of the pipes.
There is a 1/4-20 tap with a bolt in it. This is for a strap that will attach to the throttle body to keep the pipes from a blow off. "Just in case.";)
Just like the pic shows the 1/4-20 tap will be on the bottom as well as the bungs.
I also will leave the bolt in place so when you powdercoat the threads stay clean.:)
Will get this out to ya next week as well as everything else we talked about today.
Thanks again Justin.:rock:
TNVIPER said:
Is this going to be a duel intake system?..:)
This is the one part of my intercooler piping that I need welded.
Sending my pipes to Justin for powdercoat.:) :rock:
