Yesterday radiator fluid was leaking from the overflow line next to the cap, so I replaced the cap, still filling the resevior up with coolant, I also bled the coolant by the thermostat housing, still nothing. The engine is heating up past 200, and it never does that. The upper radiator hose is super hot, as is the radiator. Is it possible the thermostat is not opening, letting the coolant flow in....there is also a clicking noise when the engine is running, sounds like something is clicking on and off. Can it be the thermostat, is there any other things I can check
Appreciate the input.
