Otnielarencibia
Could you use a rc rear end on a qc?
Sure, someone will correct me if Im wrong but I understand they are the same other than the differential cover.
Leaf packs are actually bigger on the RC believe it or not. 2 Extra leaves I believe.Are there any differences in the notches for the leaf springs since one sits on the diff and the others are below?
have to swap the spring saddles around
you will have to swap yoke for drive shaft u joint ,the qc ujoint is bigger than an rc
