Rear rubbing?????
sublimeswinger
Santa Clara, CA
So, this is happening, dont know why or how. What shoul i look for? only on the passenger rear
Here ya go. How do I know if the rear shocks are bad? I took a pic of the rubbing on the inner frame of the rear
The pull on the lip, I've fixed this before, but it's back. What would cause this. I have an 05 quad, with a McGregor 2/4 drop and a baby c notch.. stock rear bel steins.
Rubber butt. Lol
What fixed it last time?
Rear or bed not center, bad bushing?
Take the wheels off and rotors. See if there are shims spacing the wheels farther apart. Might be in the diff as well. Axles missing C clips or incorrect ones
mine had this problem when i bought it, The pinion angle was off so when i loosend the u-bolts and reset the angle i pushed the rear over and tightend the bolts and it centered back.
That might make sense, since it's lowered and the carrier bearing is bad
