I need to know what wires to splice into the T56 pigtail from the 48RE wiring harness to get my reverse lights working. Literally procrastinated for 5 years.
It's simply a switch that lets power flow to backup lights or not. Yes two wires go back to 48re plug from switch. Putting 12volts to pigtail will show you which light up reverse lights. Use that wire. Other is 12v output. Voltmeter helps as wiring colors sometimes differ
