Black1
Marc T said:Mike,
Please post the Diagram!!
Thanks:rock:
Justin,
Could you elaborate on this also??
Dito and DITO!!!
:dito:
Marc T said:Mike,
Thanks:rock:
Justin,
Stay safe and I hope your house is ok after the fire is out.AWDisuzu said:hey guys, there is a fire less than 1/4 mile from my home so I am outta here for a while. I'll post a diagram asap.
Prof said:I think I just have to sit back and watch this thread...both Sean Roe and Gary Virgin have worked on my truck with breathers off the valve covers...what is the difference between pressure coming out of a breather or coming out into a catch can that has a breather?
I guess I am once again confused.
JMB Justin said:A LS1 style vacuum pump as mentioned earlier (electric) would be a much better setup however if you feel it is necessary to pull a vacuum on the crankcase. Justin
nothing at all. that is a great setup.SANCHOBA said:well... i'm using justin's catch can set-up, and routed the hoses as per his instuctions,plugged the opening on the bottom of the intake manifold and ran the hoses from each valve cover (td') into the can.:dontknow: whats wrong with this set-up?
