What's the most boost anyone has pushed thru a roe ??? Or anyone know what the max boost ?!?
Trucks lookin good man
Are those blowers roots or twin screw?
I am running 12 psi with my ROE. I have the JTS Venom over drive pully as well as the smaller SC pully. I did experience some drop off in boost at higher RPM. It was suspected to be belt slip. I have added more tension pullys to tighten up the belt, but I have not really been able to get to the track or dyno to test it since then.
It may well have been the limit of the SC capacity for volume. 700hpodessey documented a significant restriction in the throttle body being a limiting factor. Blackviper was working on a giant throttle body conversion, but I am not sure what his final results were. As for me I am using the ROE TB, and I am done looking for more power in this vehichle.
Are you running water meth?
Yes .... I run a snow performance - stage II kit, from JTSVP
What is your current A/F with meth? What air intake temps are you seeing after the blower?
Don't tell him shit! J/k. :aetsch:
LOL. Well ya know you Roe guys might, just, possibly learn something from L guys! Just sayin':listen:
That's good, my guess would be that it would help you run higher boost. I bet you'd be safe with 15psi, the 12psi figure I quoted from Roe's website is I imagine the maximum you can run with almost guaranteed no problems. I'd bet it can handle a lot more but they only say 12psi just in case some idiot runs higher boost and tunes his engine wrong and blows it up they don't want to be responsible for it so they don't offer a pulley for higher boost than that.
