straight from Chrysler website
SRT-10 SCHEDULES
There are two maintenance schedules that show the required service for your vehicle.
First is Schedule “Bâ€. It is for vehicles that are operated under the conditions that are listed below and at the beginning of the schedule.
Day or night temperatures are below 32° F (0° C).
Stop and go driving.
Extensive engine idling.
Driving in dusty conditions.
Short trips of less than 10 miles (16 km).
More than 50% of your driving is at sustained high speeds during hot weather, above 90° F C (32°).
Heavy Loading.
Taxi, police, or delivery service (commercial service).
Off-road or desert operation.
If equipped for and operating with E-85 (ethanol) fuel.
NOTE: If ANY of these apply to you then change your engine oil every 3,000 miles (5 000 km) or 3 months, whichever comes first and follow schedule “B†of the "Maintenance Schedules" section of this manual.
NOTE: Most vehicles are operated under the conditions listed for Schedule "B".
Second is Schedule “Aâ€. It is for vehicles that are not operated under any of the conditions listed under Schedule "B".
Use the schedule that best describes your driving conditions. Where time and mileage are listed, follow the interval that occurs first.
NOTE: Under no circumstances should oil change intervals exceed 6000 miles (10 000 km) or 6 months whichever comes first.
CAUTION: Failure to perform the required maintenance items may result in damage to the vehicle.
At Each Stop for Fuel
Check the engine oil level about 5 minutes after a fully warmed engine is shut off. Checking the oil level while the vehicle is on level ground will improve the accuracy of the oil level reading. Add oil only when the level is at or below the ADD or MIN mark.
Check the windshield washer solvent and add if required.
Once a Month
Check tire pressure and look for unusual wear or damage.
Inspect the battery and clean and tighten the terminals as required.
Check the fluid levels of coolant reservoir, brake master cylinder, and transmission and add as needed.
Check all lights and all other electrical items for correct operation.
At Each Oil Change
Change the engine oil filter.
Inspect the exhaust system.
Inspect the brake hoses.
Inspect the CV joints (if equipped) and front suspension components.
Check the automatic transmission fluid level.
Check the manual transmission fluid level.
Check the coolant level, hoses, and clamps.
Tire Rotation
Rotate the tires at 6,000 miles (10 000 km).
Schedule “Bâ€
If none of these apply to you, then change your engine oil at every interval shown on schedule "A" of the "Maintenance Schedules" section of this manual.
Miles 3,000 6,000 9,000 12,000 15,000
Change engine oil and engine oil filter. X X X X X
Change rear axle fluid. X
Inspect brake linings. X
Inspect engine air cleaner filter, replace if necessary. X
Miles 18,000 21,000 24,000 27,000 30,000
(Kilometers) (29 000) (34 000) (38 000) (43 000) (48 000)
Replace spark plugs. X
Inspect and replace, if necessary, the PCV orifice. X*
Miles 33,000 36,000 39,000 42,000 45,000
Miles 48,000 51,000 54,000 57,000 60,000
(Kilometers) (77 000) (82 000) (86 000) (91 000) (96 000)
Replace ignition cables. X
Miles 63,000 66,000 69,000 72,000 75,000
(Kilometers) (101 000) (106 000) (110 000) (115 000) (120 000)
Inspect engine air cleaner filter. X
Inspect auto tension drive belt and replace if required. X
Miles 78,000 81,000 84,000 87,000 90,000
(Kilometers) (125 000) (130 000) (134 000) (139 000) (144 000)
Inspect PCV valve, replace as necessary. X*
Inspect auto tension drive belt and replace if required. X‡
Miles 93,000 96,000 99,000 100,000 102,000
(Kilometers) (149 000) (154 000) (158 000) (160 000) (163 000)
Flush and replace engine coolant. X
Flush and replace Power Steering Fluid. X
Miles 105,000 108,000 111,000 114,000 117,000 120,000
(Kilometers) (168 000) (173 000) (178 000) (182 000) (187 000) (192 000)
Change engine oil and engine oil filter. X X X X X X
Change rear axle fluid. X X
Inspect brake linings. X X
Inspect engine air cleaner filter, replace if necessary. X X
Inspect auto tension drive belt and replace if required. X‡ X‡
* This maintenance is recommended by the manufacture to the owner but is not required to maintain the emissions warranty.
‡ This maintenance is not required if previously replaced.
Inspection and service should also be performed anytime a malfunction is observed or suspected.
WARNING: You can be badly injured working on or around a motor vehicle. Do only that service work for which you have the knowledge and the right equipment. If you have any doubt about your ability to perform a service job, take your vehicle to a competent mechanic
