Baggie Austin
Spot the difference!!
Before
After
Before
![DSC_0671_zpsbiho3lvi.jpg](/proxy.php?image=http%3A%2F%2Fi1326.photobucket.com%2Falbums%2Fu658%2FBaggieaustin1%2FMobile%2520Uploads%2FDSC_0671_zpsbiho3lvi.jpg&hash=1a915ef271254bc69b7c2978c2a1db6f)
After
![DSC_0756_zpsilssrxdo.jpg](/proxy.php?image=http%3A%2F%2Fi1326.photobucket.com%2Falbums%2Fu658%2FBaggieaustin1%2FMobile%2520Uploads%2FDSC_0756_zpsilssrxdo.jpg&hash=9ca17cec15e2d237bca608d47e9b7f0d)
You added a brick behind your tire?![]()
Looks better without the side steps and with the brick
:rock:yeah,looks way better Dave,now you need the drop it down and it'll look ok for a quad cab
And what is that on the wing?
what is on your fender?
The headers and decat will make all the difference.
When I was a kid we used to lower our old Fords with an oxyacetylene torch,you just heat each spring up until they sag to roughly the height you want,it's a lot cheaper than getting a kit from stateside mate![]()
Other countries require a side marker on fender area![]()
Heating springs removes the temper in the metal that allows it to spring. Without the temper, the metal is extremely brittle and can fracture at anytime!. Please do NOT heat the springs! :ahhhhh::stickyman:
Yeah its a requirement that we have indicators (blinkers i think you call them) on the front wing (fender)
I don't have them:dontknow:
