Okay, so I have done the research and read post after post after post on this forum. Many of them are older (back from 2006), so while I hate to bring up what could possibly be construed as a "sore subject", I was hoping for some updated information. Many of you have been running aftermarket plugs (anything other then OEM Champion plugs) for many many months now. So I am curious to see what your results/findings are after having done such a long testing phase. Maybe this post will bring about enough information and data that it could possibly become a sticky.
Here is the criteria…I am mainly looking for information on the plugs that N/A trucks are using...although, FI guys and gals, please feel free to chime in with your experiences (this will be good information for all). This post is not meant to be a debate on what plugs are better/best. All I am looking for is factual information based on your own personal experiences. Again, I beg that you please do not hijack the thread into a plug debate.
I am especially interested in the following plugs:
-Stock Champions
-Bosch Platinum 4's
-Bosch Platinum Ir Fusion
-NGK Iridium's
1) Is your vehicle N/A, FI, or Nitrous?
a) If FI or Nitrous, are you using a colder plug?
2) What brand/type of plugs are you currently using?
3) How many miles have you put on your current plugs?
4) Have you checked the plugs since you first installed them?
a) If yes, how many miles between initial installation and checking them?
b) When you pulled the plugs, how did they look? (i.e.…fouled / appropriate for the given application….)
5) If you used anything other then the stock Champions:
a) Did you notice a performance difference (i.e.…improved throttle response / improved acceleration / improved gas mileage…or just the opposite, any decreased performance)?
b) Did you go back to stock Champion plugs after using a different brand of plugs? If so, why?
c) Would you (and are you) going to stay with your current choice of plugs or do you plan on going back to stock Champion plugs? If planning on going back to stock, why?
d) Do you feel your choice of plugs is a better alternative to the stock Champion plugs? If yes, please expound. If No, again, please expound
6) What is the part # of the plug you are using? (again, please note if this is a stock temp plug or one step colder plug)
7) Any other experiences and/or comments that you would like to share (in regards to spark plugs and ignition…Ha! …that could be a loaded comment there with this group!)
Thanks for all your input and experiences.
Joe
-Stock Champions
-Bosch Platinum 4's
-NGK Iridium's
Joe
