Squeak at 2-5 mph
Halligan
Phx
I've got a squeak coming from the passenger side front tire area about about 2-5 mph. I can't tell if it goes on after 5mph just because the motor is too loud :). Any ideas? I'm thinking wheel bearing? I've only got 20k on the truck, I would hope that a wheel bearing wouldnt go that soon.
The squeak comes not when I'm breaking, but just when I'm coasting at that speed.
Maybe it is a tire. Switch the tires around and see if it changes!
sounds like your wheel bearing. jack that side up and wiggle the tire to if the bearing feels loose.
I had a few too, but when it was up on the lift getting its oil changed i hit all the front suspension bushings with a little WD-40 and they went right :D away
I'll try that this week, WD-40. If not, I'll assume its the wheel bearing. argggggggggggggggggggggggg. :argh:
