Srt boost gauge for the Srt 10 truck
BAD SNAKE
DC/MD/VA Area
Was checking to see if it's possible to get and an autometer boost gauge that has the SRT logo on it so it matches the Oem gauges. Or use a Srt gauge from a Srt 4 or other boosted models that have the Srt boost gauge. I noticed some of the factory Srt boost gauges are electrical? Thanks for the help
I've had custom SRT (and other) Gauges made by Speedhut. good work and quick turnaround.:rock:
Yes you can use a boost gauge out of a SRT 4 neon. It's mechanical and you'll need to run a vacuum line near the brake booster.
I have a mopar white faced mechanical 15psi gauge it matches pretty good in the daylight but at night it has a blue led built in. I'm very fussy when it comes to the fine details and the blue doesn't bother me. I've got the aem wideband up top, mopar boost in the middle and stock oil temp at the bottom
Does it match the rest of the Oem gauges as far as looks and colors, back lighting?
I see that the Oem boost gauges from the Calibers are all electrical. I did check out a few SRT4 boost gauges. Also why do you guys use the line from the brake boost?(just wondering) I have always got a more accurate reading by tapping the discharge of the supercharger or turbo.
So theres no way to change it out to a green led.
Thanks for all the input guys. Cheers
You could probably send the gauge out to get customized but I spent alot of time trying to find an exact match and couldnt. I tried autometer NV green led looks really close but the led is very bright ask Norbert ( Hucksrt10 ) I sold him all my brand new NV gauges I didn't use. The older srt4 boost gauges are like the procomp ultralite by autometer but I found that the 194 bulb isn't bright enough and by adding the autometer green led 194 bulb still not a close match. I got mine about 2 years ago so maybe something else has come up.
You build the Speedhut one the way you want it with day/night colors, face, font, etc. Nice gauges since many of them are programmable with alarm lights, etc.
