I'm having some problems with the starter on my truck.....it seems that once the motor runs for a while it has some difficulty cranking and sometimes won't crank at all.....when she's cold she's fine.....when she soaks some heat she's worse....is that a typical problem? do starter motors suffer from heat soak related problems? i'm running mopar long tube headers, anyone have a similar issue? if I replace the starter motor is there anyway to help prevent this from happening again? any and all advice would be welcome....Thanks in Advance!
