lightningeater
Is it a common problem for the stock tranny in my RC to pop outa reverse when its cold? I assume it is but I just want to be sure I don't need to take it in.
bucke77 said:what do you mean pops out?
I did think of something to add but I am fairly positive it's not what you are encountering . Reverse has a solinoid lock out so you can not shift into R while rolling . We have done a bunch of the Tremac's and had a few the link on the solinoid had some drag and would retract but still make it tight . Like I said once I started to ,start it run it from 5 to 6 with the clutch in then go to R it has never done it only when I try to hit R , it just likes to get wiggled so it knows you carelightningeater said:sounds like i'm having the same problem as what hotrodmike is talking about. it doesn't necessarily pop out of gear, it just isn't fully engaged so it just grinds and feels like its about a half inch out of place. i'll try changing to a synthetic fluid and hope that it warms up around here soon.
