seethrough
Member
Yeah you can't find these anywhere anymore. They say in stock but when you order that changes quickly.![]()
Good to know - I think I might start hunting down a spare just in case I need one some day.
So I called dodge.. They said they no longer make the part and are able to get the part. They gave me a #5245084, then a cross reference #SU3018 for autozone which isn't able to get it any longer either. Then I searched more and found another #5S1272 which isn't available any longer either. How are people fixing there shit?.. Does any one have a extra sensor by any chance?
I already replaced the crank sensor
Never went to go get a gauge but know I had nothing to do with 1 cyl being low or even a hole in the piston.. It doesn't make sense, it's a timing issue.. Valves opening wrong time allowing blow by.. Running like shit.. To rich.. It all goes together. How bout that part #
There is no sensor that is going to cause the valves to open at the wrong time. If you think this is what is happening it would be related to the timing chain skipping a tooth and a compression test would verify this because you would not build compression if the valves were "out of phase" with the crankshaft. Blowby is going to be caused by a mechanical issue not a sensor.
Isn't this the same motor for the Viper? ?? Are all of those owners going to dump their cars when theirs goes out? ??
To answer this question
Yes
This is a current issue with all Gen I, Gen II and Gen III Vipers and Viper Trucks.
I haven't heard of anyone dumping there Vipers
