bmxam962
Yes for those who asked, the truck is alive. I have put a few thousand miles on it this spring. It does need a tune as it is running quite rich on the old Procharger tune, so there is plenty of gains waiting once I get Chris to work his magic on it.
It pulls twice as hard as the Procharger ever did, sounds unreal (5" open exhaust) and I am only running it at 10 psi so far, about 10 psi more to go yet!
I can put it in 5th gear on the highway doing regular ground speeds and slowly push the pedal down, the turbo starts to spool and it takes off like nothing I have felt before. And keep in mind at the same time as the turbo install I went from 4.56:1 to 3.73:1 gears, which makes 6th gear unusable at highway speeds as you can travel at 70 mph at something like 1000 engine RPM.
Like I mentioned, I have had them all and I will NEVER own a belt driven power adder again in my life. I am convinced turbos are the only way to go.
Please man that is last thing I want to hear seriously. Take your turbo power conversation else were please.
