Geodriller
As many o you know my truck put up some weak numbers on the dyno.
Q1, is it possible my clutch was slippiong on the dyno and is part of my problem
Q2, if so, would the numbers be so consistant or if it was slipping would the resul;t numbers vary more?
Q3, more of a statement really. my truck runs a little inconsistent. sometimes feels much stronger than other times even if there is not much diff in ambient temps.
Q4, how easy is it to drop a T-56 in an 06??
I have tried to test the clutch by going WOT in gears, and there is no slippage, butthere is also not much power when i do it. just a thought here and would make me feel better if i can drop the tranny and check the flywheel and clutch
Thanks.
Thanks.
